Comfort / Comfigurator Running Config
 Posted: Monday Sep 5th, 2016 02:26 pm
Vangelis
I have not played with my Comfort config for sometime now (as its stable), however I know on my PC where I store all my configs, there are a couple that were for testing purposes.
The problem I have is that I stored them all in date format eg Config_File_060815 and I know that the running config is a couple of revisions earlier (in date) than my test files.
Is there a way that I can query Comfort to check which config file is currently enforced?
I know I could read back the running config to a file but I always have issues with this this...
Vangelis
 Posted: Monday Sep 5th, 2016 02:43 pm
Not sure if you can get from Comfort memory location (you would hope so) via a DL command but the date is stored in the CCLX file if you open and look in notepad say.
Look for "TimeofLastWrite".  You'd still need to check all of your CCLX's but may be quick still if you only have a few 10's of backups.
Ju
Attachment: 2016-09-05_11-39-30.jpg (Downloaded 20 times)
 Posted: Monday Sep 5th, 2016 03:06 pm
Vangelis
Thanks for that, will give it a whirl...
Vangelis
 Posted: Monday Sep 5th, 2016 03:46 pm
This may not be what you need but you cab restore previous versions of your configuration
see http://www.comfortforums.com/forum20/
 Posted: Monday Sep 5th, 2016 04:45 pm
No sure this is what Vangelis needs;  I believe he wants to know amongst all of his manual backups, which one is the current active one in Comfort.
Is there a memory location (think I would have asked you this in the past for CC dev) that stores the date of last write from CCLX or is that only stored in each CCLX file at the PC end?
u
 Current time is 09:36 pm
