Sunset/sunrise calculation problem
 Posted: Saturday Apr 19th, 2014 10:23 pm
Julian.Driver
I have just installed 3.8.6.0 and find that it calculates sun set/rise times incorrectly. This error may have been in earlier versions but I cannot be sure.
example:
My location, Leeds England is given Lat 53 deg 45' and Lon 1 deg 30' which is correct. Daylight saving time is used and correctly dated as +60 min on 25th Mar.
Comfigurator calculates Sunrise as 4:19 and sunset as 19:45 on 5th May for example
The actual values are     Sunrise as 5:23 and sunset as 20:44
I suspect a bug
Julian Driver
 Posted: Sunday Apr 20th, 2014 06:51 am
Comfigurator calculates Sunrise as 4:19 and sunset as 19:45 on 5th May for example The actual values are Sunrise as 5:23 and sunset as 20:44
The times displayed in sunrise/sunset are without the effect of daylight saving
Hence if daylight saving is in effect, the times have to be increased 1 hour, so the "real"  sunrise would be 5:19 and sunset at 20:45 which is very close to what you say are the correct times.
The cities.csv file contains the data for sunrise and sunset times used in Comfigurator.
 Posted: Sunday Apr 20th, 2014 10:00 am
Julian.Driver
I understand, the 1 hour DS adjustment is assumed rather than explicit. Thank you.
 Current time is 01:59 am
