Alarm Type Names in Comfigurator 3.7.6
 Posted: Sunday Oct 13th, 2013 08:00 pm
simond
I note this from the "Whats New in Comfigurator 3.7.6" post
Security Types > Alarm Types
The Alarm Types that are referenced ie in Blue should have the Names fixed ie not editable. This is because the name reflects the alarm which should not be changed. Unreferenced alarm types (shown in black) can still have their names changed
I've possibly been a naughty boy and already changed the name of Alarm 18 - CMSTest - as I've repurposed it for something else (used for reporting low light from a photocell, also forming a daily message confidence test).
Now I've upgraded to 3.7.6, I'm stuck with my new (but temporary) name, and can't edit it. Is there anyway to override the Alarm Type name for these now 'fixed' types?
Or is it just a case of slapped wrists for being a naughty boy and changing it in the first place!
 Posted: Sunday Oct 13th, 2013 08:44 pm
simond
Ok, I've been an even naughtier boy now and modified it in the XML in the .cclx file.
Is this a really bad idea?
 Posted: Monday Oct 14th, 2013 03:41 am
CMS test is not really used by Comfort. It is used in a default response  but that response is not normaly used
Hence you can change it
The ones that should not be changed ae Intruder, Panic, Fire, Tamper, Duress, Trouble. Comms failure etc that are needed by the system
We should clarify that better in future
 Posted: Friday Oct 25th, 2013 10:35 pm
gaynorc
I changed the names of several alarm types to use them for my own purposes. Not the obvious ones - intruder, etc. This enabled me to send meaningful text/SMS messages concerning my own type of alarms. Water alarms, medical alarms, etc.
Now I see I cannot edit many of the names at all.
This ability to edit the name seems to be based on the property of the alarm type: if its referenced anywhere in the file, it cannot be edited.
Can this be reversed?
 Posted: Saturday Oct 26th, 2013 08:26 am
You have to remove the references to the alarm types so that they are not used
You can change the names of the alarms in  GSM4 instead so there is no need to change the names in alarm types
 Posted: Saturday Oct 26th, 2013 10:46 am
gaynorc
GSM4? I have had my GSM for a number of years. My GSM is currently on 6.081 firmware. If I update it to 7.029 firmware will I be able to change the names of the alarms?
 Posted: Saturday Oct 26th, 2013 11:19 am
UCM/GSM4 will allow you to indpependenyly name the alarm types, user names and zone names as well sending help messages to tell you what are the commands you can send to Comfort, see http://www.comfortforums.com/view_topic.php?id=3527&forum_id=48
See the section on upgrading from UCM/GSM3
You can buy a GSM4 submodule and an EEPROM to upgrade to UCM/GSM4
If yours is a SIM900 module then you do not need to buy the submodule
 Posted: Saturday Oct 26th, 2013 01:43 pm
gaynorc
Thanks ident.
I have posted to the main forum topic a request for help in identifying my upgrade path to GSM4.
 Current time is 02:31 am
