Comfort Automation/ Security System Forums > Software Applications > Comfigurator > Request - Keep Responses Fixed after editing
 Posted: Friday Nov 25th, 2011 10:17 pm
schford
In the next version update of Comfigurator - can we keep the response fixed eg the same number after we edit it if the Fixed check box is ticked before editing?
Stuart
 Posted: Saturday Nov 26th, 2011 12:34 am
Response numbers may have to change due to editing.  Response slots take up 8 bytes. A response may take up several Response slots depending on its length
Hence if you add codes to a Response it may run over to the next Response slot which may be fixed so it has to find a new number where there are enough slots to fit in Hence when yoou edit a Response, it becomes unfixed. You will have to re-fix it after editing
 Current time is 02:31 pm
