Posted: Monday May 7th, 2007 10:09 am |
Posts: | 3497 |
It is possible to prevent a keypad from announcing eg while arming and disarming the security system. This may be useful for keypads in childrens rooms which are used for Baby Monitoring, where you dont want the keypad to make noise at other times
Go to Program Menu (ie User Menu Press 9). Press 3 for Security Settings and 1 for Voice Report. The menu will say "Voice Report ON. Press 1 for On, 0 for Off) which means announcements are enabled. Press 0 for Off to disable Voice announcements.
The keypad will be silent for announcements. However the Function keys and voice menu on that keypad can be heard when accessed as usual.
If you go into this mode, you wil find that pressing the Arm keys on this keypad will not give the "Please Exit" announcements, but other keypads will have the announcement.
Resetting the system will cause announcements on the keypad to go back to normal
Posted: Wednesday May 9th, 2007 04:11 pm |
palmlodge
Advanced Member
Posts: | 477 |
Can you do this programmatically via the startup response ?
Posted: Thursday May 10th, 2007 01:53 am |
Posts: | 4172 |
Certainly
In Response Wizard > Keypad > Keypad Announcements On/Off
This will allow you to disable selecetd keypads for announcement at startup
