Comfort Home Automation/ Security System Forums > Support > FAQs - Users > Does Comfort have a Real-time Clock?
 Posted: Monday Dec 4th, 2006 12:38 am
adlim
Comfort does have an accurate  real-time clock and calendar which is normally accurate to within 4 to 10 minutes per month. However the time is reset to a default time whenever the system completely loses its power and battery backup. For a working installation, there is a back-up battery which ensures that the system time is maintained until a flat battery situation.
 Posted: Monday Dec 4th, 2006 01:40 am
The UCM/ETH03 is able to synchronise the time with an Internet Time server using the UCM/ETH03 so the time can be kept very accurate
http://www.comfortforums.com/forum113/3695.html
 Posted: Friday May 29th, 2015 05:56 pm
For those without the ETH03 time synchronisation feature, the Comfort Time can be adjusted by a value in seconds to correct any time inaccuracy
Go to Configuration > Modules and Settings > Time Adjust as shown below
Enter a value of - 60 to +60 seconds in the field to make a daily adjustment to the time. First you will need to determine approximately how many seconds fast or slow the Comfort Time is every day. For example if the Comfort time is fast by 10 seconds every day, enter -10 into the field to slow down the time by 10 seconds a day
If the time is 10 seconds slow every day, then enter +10 to speed up the clock by 10 seconds per day
NOTE: Set to 0 if the ETH03 Time sync is used
 Current time is 12:52 am
