Comfort Automation/ Security System Forums > Support > FAQs - Technical > After Entry Alert, no Intruder Alarm
 Posted: Sunday Jun 11th, 2006 07:32 am
When the entry door is opened when the security system is armed, the Entry delay allows time for the user to disarm. When the user code is not entered within the allowed time, the Intruder Alarm is activated If this does not happen and the beeping tones from the keypads continue, it is due to a wrong setting in Comfigurator.
Go to Secuirity Types > Non DetectorAlarms
The 1st Nondetector alarm called Intruder Alarm should be set to the Alarm Type called Intruder Alarm, and not to a blank or null setting
This is required because the alarm caused by Entry delay is not triggered by a zone activation
see the attached screen capture
Attachment: Nondetector.jpg (Downloaded 45 times)
 Current time is 09:03 pm
