Posted: Tuesday Nov 21st, 2006 02:45 am |
The draft of the guide to adjusting Tuning Parameters is now available on our website at http://www.cytech.biz/Downloads/Files/90/Tuning%20Guide.pdf
This shows how the parameters can be adjusted to achieve optimum performance for the two way intercom system for Phone to Keypad/Door Station, Keypad to Door station, and also shows what to do if the DTMF signal cannot be detected from the phone
Posted: Sunday Oct 28th, 2007 08:54 am |
Posted: Wednesday Apr 2nd, 2008 04:00 pm |
technik23
Posts: | 36 |
Is there a final version available? The draft is no longer on this link?
Than ks
Posted: Thursday Apr 3rd, 2008 01:33 am |
Posted: Sunday Dec 12th, 2010 06:11 pm |
bryanajones
Posts: | 54 |
Is there a current tuning guide for door phones and keypads? This link no longer works.
I have some issues when talking to someone who is using the door phone (DP03X-WI & DM02). If I pick up a house phone they other person can hear me ok. If I answer via the keypad (KP04) the volume is so low they cannot hear me.
...also when a user presses the door bell button outside, the "Ding Dong" almost knocks them off their feet it is so loud. Is there a way to lower this?
Bryan.
Posted: Monday Dec 13th, 2010 03:34 am |
Posts: | 5493 |
The tuning guide can be downloaded from http://www.cytech.biz/tuning_parameters_guide.html
The link has been fixed
Make sure you are using the default tuning parameters. If you started your file using an older version of Comfigurator, you may be using an older set of tuning parameters which are not opmitised
Go to File > Import > Configuration Items and select the def34.cct file, then choose Tuning parameters to import
Posted: Monday Dec 13th, 2010 01:23 pm |
bryanajones
Posts: | 54 |
Sorry if this is an obvious question, but where can I find "def34.cct" to extract the parameters?
The version of Comfigurator I started with was the one prior to the latest release (3.1.9?).
Posted: Monday Dec 13th, 2010 11:33 pm |
hendy
Posts: | 221 |
In Comfigurator software the "def34.cct" can be found by opening a New File and in the Select Template dialog box click on "Browse for template file" button and then point to the 'Config' folder under the 'Comfigurator 3' folder.
It is always recommended to use the latest version of Comfigurator software as it would have fixed the bugs found in the previous versions.
Posted: Tuesday Dec 14th, 2010 12:47 am |
Posts: | 5493 |
def34.cct is also the Default Template file for Comfort II Ultra, ie if you do FIle > New and select Comfort II Ultra, you are actually opening the def34.cct file template
Posted: Tuesday Dec 14th, 2010 04:01 pm |
bryanajones
Posts: | 54 |
when you say use the latest version as it fixes bugs, are you saying start with a new template file? or can I continue with the same cclx file?
Posted: Wednesday Dec 15th, 2010 05:27 am |
Posts: | 5493 |
You can continue with the same cclx file as long as you import the tuningg parameters. The bugs are fixed with Comfigurator 3.2.4 but the tuning parameter values are not automatically changed in the old file
