Comfort Home Automation/ Security System Forums > Support > FAQs - Technical > Write User Codes to Comfort does not change User Codes
 Posted: Wednesday Nov 28th, 2012 12:49 pm
If you change the user codes in Comfigurator and Write to Comfort but the user codes are not changed, this is because in Configuration > Modules and Settings > Write User Codes checkbox is set to NO
"NO" is the default setting. The purpose is to prevent an installer who comes back to change the programming of the system from writing over the user c odes that have been changed on the keypads
 Posted: Thursday Nov 29th, 2012 07:36 pm
With write User Codes checkbox set to NO then there is "NO" access to the engineer test menu either.
 Posted: Friday Nov 30th, 2012 01:18 am
I dont understand what you mean
Not checking Write User Codes prevents the user codes in Comfigurator from being wriiten to Comfort so the original user and engineers codes are unchanged
It should not affect Engineer Test Menu
 Current time is 03:29 am
