Posted: Thursday May 10th, 2012 08:57 pm |
idheath
Posts: | 87 |
I have a Comfort II system with 2 UCM05's (Serial versions).
I'm planning to upgrade everything to the latest and greatest versions.
I've checked the relevant posts on the forum but just want to be 100% clear to make sure I don't "brick" anything :-)
I can't remember the exact version my Comfort II system is (but it's >=5.183 ULT) and currently the UCMs are both at 5.212 version.
So what's the recommended order to upgrade, i.e. UCMs first or Comfort main-board?
I appreciate that I'll need to use the "cable method" until everything is at 6.xxx.
Also can I jump straight from my current versions straight to the latest 6.xxx versions for both Comfort & UCM?
Posted: Friday May 11th, 2012 12:55 am |
hendy
Posts: | 221 |
Well, I'd recommend to upgrade the UCMs first then only the Comfort main panel.
And yes, you can jump straight from your current versions to the latest 6.xxx for both Comfort and UCM.
