Comfort Automation/ Security System Forums > Support > FAQs - Technical > When does Security Mode change value?
 Posted: Wednesday Feb 8th, 2012 01:22 pm
AdrianL
At what point during the responses Security Off, Away Mode etc does the attribute Security Mode change its value? At the beginning or at the end or perhaps it's not defined? I suppose my real question is can I tell which mode I'm coming from during these responses, in particular Security Off?
 Posted: Wednesday Feb 8th, 2012 07:26 pm
The security mode is changed before the security mode responses so you would not be able to check the previous mode
You can save the security mode in a counter in each mode eg off = 0, away = 1, night=2, day=3 in the security mode response. You can check the old security mode in the same security mode response before you change the counter
 Posted: Thursday Feb 9th, 2012 02:10 pm
AdrianL
Thank you for your response. I think it's a shame that the Security Mode attribute is not changed at the end of these responses. It must be quite common to want to know which mode you are coming from, especially in the Security Off response, and although using a counter as you suggest is a work around, it is not as easy and the meaning of the code is less obvious as you have to remember the mapping between the Security Mode and the integer value of the counter. Would it be possible to change the way it works, or perhaps better introduce a new attribute that behaves in this way?
 Posted: Thursday Feb 9th, 2012 03:49 pm
TheMax74
Hmmm...
If security will be changed after responses, all my logic will fail miserably!
 Posted: Thursday Feb 9th, 2012 03:56 pm
AdrianL
That's why I suggested a new attribute rather than changing the existing.
So do you have one response that is called for several different changes of security mode?
 Posted: Thursday Feb 9th, 2012 04:26 pm
TheMax74
In this case, i use a Counter, as suggested by ident. This Counter also updates my Gira Homeserver via KNX group address.
 Posted: Friday Sep 23rd, 2016 01:31 pm
cgiltrow
Hi Chiu,
Does the LastSecurityMode attribute in the If statement now address this requirement?  I used to use coumters to achieve this, but the LastSecurityMode would be more elegant and if it addresses the same requirement I would rather use that.
As a matter od interest, when did this become available?
Regards,
Clinton.
 Posted: Saturday Sep 24th, 2016 06:19 am
Yes, the Last Security Mode can be used for this purpose
Last Security Mode is set the the security mode after the security mode response.
Hence when you arm or disarm again, this will give you the previous security mode
This was added in 2013 so it may have been done in response to the request in this forum but it was not known!
 Current time is 09:58 pm
