New CPU and LEM
 Posted: Thursday Aug 8th, 2024 04:39 pm
The 'new' LEM for the new CPU
Makes it VERY difficult to perform a manual system reset as the reset button is under the pcb !Also the pcb is VERY close to the 12v Ka Kb zone terminals making it VERY difficult to remove then
 Posted: Friday Aug 9th, 2024 01:05 pm
Presume this is a design fault and nothing can be done about it now !
 Posted: Saturday Aug 10th, 2024 02:34 am
On the Comfort CPU board you can plug in Output module (OP03), ETH03, LEM02B at the same time.
 The Reset switch is positioned between these plug in modules so you can press it. although with a bit of difficulty if you have large fingers.
 I would not call it a design flaw - it is a space limitation in order to keep the existing PCB size and Hole locations. There are hundreds of components on the Comfort PCBs
 Current time is 05:03 pm
