The photo below shows the CM9001 DSP side with the J104B which is the connector with 2 x 3 way shunt that should be inserted if the DSI01 is not used. If DSI01 is to be inserted then the 2 x 3 shunt should be removed to allow the DSI01 to be plugged in. If the 2 x 3 way shunt is not inserted in the PCB (when there is no DSI01) then the TEL OUT to the phone will not be connected
Attachment: DSI Shunts 2x3 small.jpg (Downloaded 11 times) Last edited on Friday Nov 18th, 2022 05:35 am by slychiu
