Comfort Automation/ Security System Forums > Products > Environmental Monitoring System > KP04AET Keypad with Temperature Sensor for Environmental Monitoring Systems
 Posted: Sunday Oct 20th, 2019 06:29 am
The new KP04AET Keypad has the same features as KP04AE (see http://www.comfortforums.com/forum139/4912.html ), but in addition  includes an internal Temperature sensor. The temperature reading is saved in one of 32 Comfort Sensor Registers which can be monitored on the Keypad LCD or on other KP04AE keypads.
The KP04AE/KP04AET Keypad  LCD display which shows Alarms, Zone/Input Status,   Temperature, Humidity  and other sensor readings for CM9001-EMS Environmental Monitoring System.
Specifications
  • Dim: 89 x 160 x 31 mm. Carton 92 x165 x45 mm
  • Weight: 177 g
  • 2 Lines by 16 character LCD. adjustable backlight.
  • Power Supply: 12V DC from CM9001-EMS
  • Current Consumption:  50 mA idle (No voice)
  • Speaker for announcements
  • Up to 15 Keypads (KP04, KP05, KP06/, KT05)
  • Sensor Display Resolution: 0.1 deg c
  • KP04AET Temperature Sensor 0 to 45 deg C,  Accuracy  1 deg C
The Temperature sensor can be assigned to a Comfort Register Sensor Number, and displayed on the LCD Display of this and other KP04AE/KP04AET keypads. The Temperature Setpoint can be displayed and incrementsed on decremented, or  Disabled.
For CM9001-ULT, the temperature is also saved in Comfort Sensor Registers, but KP04AE will not display the Sensor values and setpoints. KP04AE and KP04AET can only be used for CM9001-EMS
Other sensor modules include  MSM01 Multi-Sensor Module with built-in Temperature and Humidity Sensors http://www.cytech.biz/brochure/msm.html , TSM01 Temperatire sensor Module with external Thermistor sensor
KP04AET Website
http://www.cytech.biz/brochure/kp04ae.html
 Current time is 04:49 pm
