Comfort Automation/ Security System Forums > Products > UCM > UCM/USB > UCM/USB does not communicate
 Moderated by: slychiu, admin
 Posted: Sunday Mar 19th, 2017 07:50 am
See http://www.comfortforums.com/forum73/2431.html
 Posted: Monday May 29th, 2023 06:02 am
If UCM/USB  fails to log in, press the RESET button on the UCM and try again. The USB cable should be plugged  in to the PC before turning on the UCM, otherwise this issue map happen. Resetting the UCM with the uSB connected will fix it.
The problem occurs because of the detectiopn of Wifi Submodule at reset.
The newer SMT Version of the UCM should not have this problem
 Current time is 05:15 am
