Additional Smartthings hub
 Posted: Tuesday Mar 28th, 2017 02:13 pm
Swiss-Toni
I am planning on adding an additional Smartthings hub for a partion system and wondering if anyone has done this yet.
my concern at present is that the partion uses a different code for access and I am wondering will you have to add the additional code into the R-PI with a coma after the main code as the smarthings hub will have its own entry code programmed.
 Posted: Wednesday Mar 29th, 2017 03:49 pm
mattbrain
This is an interesting question. If you have 2 SmartThings Hubs I think you will need two RPi's too.
This may cause issues with discovery (as you will see all the devices) so you will need to select only the devices appropriate for the partition in use.
For alarm setting and control I may need to modify the code to act on the relevant partition - i need to look at the documentation to check this out.
Do you have a comfigurator file you can share with me so I can load it onto my lab system?
Thanks,
Matt
 Posted: Thursday Mar 30th, 2017 10:45 am
Would you also need 2 UCMs?
 Posted: Thursday Mar 30th, 2017 06:43 pm
Swiss-Toni
If you are refering to Etho UCM I dont see why you should need tw0 as the R-PI should be able to share the port or use the 1002 port although this may block you from using a mobile phone App not tested it yet so I cant swear by it, I think it will be a case of wait and see with this project......
 Posted: Tuesday Apr 11th, 2017 12:53 pm
mattbrain
Hi Swiss-Toni
Did you get any further with this?
Thanks,
Matt
 Posted: Wednesday Apr 12th, 2017 08:46 pm
Swiss-Toni
Hi Matt,
Not got any further at all at the moment had other projects on the go. I will still have to move on this as this is set in my own porpoety with an Outhouse set up as a partion......
 Current time is 10:06 pm
