Crash or corrupt again
 Posted: Thursday Mar 9th, 2017 04:14 pm
bagushandhoko
Hi Matt,
after replace old 16 Gb SD card with 8 Gb new one, the problem of can be accessed after sometime continue. I should re copy image again to make working.
 Posted: Wednesday Mar 15th, 2017 03:21 pm
mattbrain
So even replacing the card results in the same issue that the Pi freezes and needs to be restarted?
Ok, some more things to try:
Can you check the PSU you are using for the Pi can provide enough power; You are best served with a PSU which can provide 5v @ 2A - so a high powered phone charger (as you get with a new iPhone or Samsung device, not a standard USB 5v @ 1.1A. If you are in doubt, Pi resellers do sell reliable PSU's.
Let me know how you get on.
Thanks,
Matt
 Posted: Thursday Mar 16th, 2017 07:08 am
bagushandhoko
I using 2.5 Amp.
Restarted not solve the problem, i need to copy the image again
 Posted: Monday Mar 20th, 2017 01:29 pm
Swiss-Toni
I have had a similar problem, however I found that it was due to the R-PI being turned of unexpectadly, this seems to stop the R-PI from working and the way I got round this was to do a clean reinstall on the card after sds format etcher ect on the card, the problem only occurs when the power was interupted and Pi was not shut down from web interface. if your power supply has a intermitten fault this maybe the answer
 Posted: Monday Mar 20th, 2017 03:52 pm
Swiss-Toni
After playing round with this I found that the cclx just needs to be uploaded!
 Posted: Monday Mar 20th, 2017 04:07 pm
bagushandhoko
Swiss-Toni wrote: After playing round with this I found that the cclx just needs to be uploaded!
You have same problem Toni ?  Because in my case I can not access through web anymore
bagushandhoko
 Posted: Tuesday Mar 21st, 2017 01:27 am
Swiss-Toni
1) Does it work when you go through a clean install back on the card
2) If the R-PI does not work, then their is a potential fault with the R-PI
3) If R-PI does work, the likelihood is that there is an intermitten fault with the R-PI power supply
4) My fault was by me interupting the power supply causing the failure! (therefore the fault was NOT with R-PI or softaware or even my Power supply)
Any luck this will give you a bit of help with your issue!
 Posted: Thursday Mar 23rd, 2017 04:58 pm
mattbrain
Hi All
It's worth bearing in mind that there is no protection on the disk in the event the RPi power is interrupted. Swiss-Toni is right to stop the service before pulling the power.
I'm going to update the web gui to stop the Pi so power can safely be removed.
Thanks,
Matt
 Current time is 08:48 pm
