Releases (Latest at top)
 Posted: Wednesday Feb 1st, 2017 06:16 pm
mattbrain
Release 1.0.1a
This is the latest release
Download disk image here 1.0.1a.img.zip existing users may upgrade using the Upgrade button in the Web GUI
Supported Devices
  • Samsung SmartThings
    • Inputs, Outputs, Flags, Counters, Alarm Mode and State, Responses, Doorbell.
Changes
  • Fixed: alarm.config.template no contains windows LF and can be easily edited on Windows machine. Existing users may download a good alarm.config.template file from here: alarm.config.template
  • Fixed: Alarm Mode change to mode without a SirenName entry in .cclx causes restart of service
  • Fixed: Changed update process to get update file synchronously. Previous updates may fail if file is not downloaded fully before starting update.
  • Fixed: Registration with send usage data flag now correctly registers
  • Enhancement: Add link to release notes on Web GUI
  • Enhancement: Add link to Forum and Mailing list on Web GUI
  • Enhancement: Updated ComfortAlarm Zone Device now includes Capability.ContactSensor allowing it to report Open/Closed as well as Motion/No Motion
Known Issues
  • Discovery is limited to around 130 devices depending on length of device names. Please contact support if you have more devices for process to discover many devices
Notes
  • You will need to update the ComfortAlarm Control device from the SmartThings page in the Web GUI in order for the Doorbell device to function properly.
  • You will need to update the ComfortAlarm Zone device from the SmartThings page in the Web GUI in order for the Zone device to report Open/Closed
 Posted: Tuesday Feb 7th, 2017 01:35 am
mattbrain
Release 1.0.0a
Download here 1.0.0a.zip
Supported Devices
    • Inputs, Outputs, Flags, Counters, Alarm Mode and State, Responses.
Known Issues
  • Door Station Bell Button push will cause a restart of the UPNP manager; impact will be loss of communications between Comfort and UHAI devices for up-to 10 minutes.
  • Requesting a stop of the UPNP manager via the web GUI when it isn't running will result in an error message. Service availability is not affected.
  • Registering with 'send usage data' checked will not complete. Service availability is not affected, uncheck the 'send usage data' checkbox to complete registration.
 Posted: Tuesday Feb 14th, 2017 09:23 pm
mattbrain
Release 1.0.0c
Download disk image here 1.0.0c.img.zip, existing users may upgrade using the Upgrade button in the Web GUISupported Devices
Changes
  • Fixed: Doorstation doorbell press event no longer causes restart of service
  • Fixed: Start, Stop, Restart on the web GUI only available when the service is in the appropriate state
Known Issues
Notes
 Current time is 03:39 am
