HIO Hotel Room Logic Controller
 Posted: Saturday Dec 24th, 2016 11:50 am
Cytech's new HIO01 Hotel Room Controller is our new product for the hotel sector, making use of our automation technology in a new application.
The HIO01 is a Hotel Room Logic Controller to be used with electronic switches and relays for control of lights and appliances. It can be connected to ELV (Extra Low voltage) switches  with push buttons with or without leds and can implement energy saving functions.
Highlights
  • 16 Programmable I/O channels for ELV Switches linked to 16 Outputs which can be connected to  HIO-RLY1 Relay module
  • LEDs on the ELV switches can be dimmed when in the off state.
  • 2 x 0-10V outputs for dimming lights.
  • Energy Saving Features:  Room Occupancy detection, Open Door Courtesy Light, Toilet Occupancy,  Window/Aircon Linkage
  • Programmable Timers for Occupancy, Courtesy,  Keycard off, window/aircon linkage.
  • Optional temperature sensing.
  • Programmable Scenes: Welcome, Master On/off, 4 Scenes, Courtesy Light, Toilet Occupancy
  • HIO-RLY 8-way 6A relay modules for easy connection.
  • Programmable by Comfigurator, including Firmware upgrading
  • Can be interfaced to other lighting/control systems, like KNX, Cbus, Modbus, Z-Wave
Specifications - HIO
  • 16 programmable I/O channels for Extra Low Voltage (ELV) switches linked to 16 Open-colector Outputs. Each channel is a dual function input and output which can drive an indicator LED and switch button at the same time.
  • Each of the 16  Open collector Outputs follows the state of the corresponding channel number.
  • Plug in Connector to Relay Board 8 x 230V rated 6 A relays each so there is no need to wire outputs to the relays.
  • 0-10V output x 2 (used to control lighting)
  • RS485 interface – This is a slave port polled by a master controller. ID 1 to 15
    Power supply 12 V DC
  • 3.3V/5V  power supply (alternate voltage regulator)
  • 4 x ID Dip Switches for ID
See HIO01 Manual at  http://www.cytech.biz/hotel_room_controller.html
HIO-RLY
The HIO-RLY is a relay module with 8 relays mounted in a DIN Rail enclosure which is connected to the HIO01 Hotel Room Controller. 2 HIO-RLY with 16 relays can be connected to one HIO01
The HIO-RLY manual can be downloaded from http://www.cytech.biz/hio_relay_module.html
Interface to other systems
The HIO can be interfaced to other systems including KNX, C-Bus, Modbus or Zwave using Cytechs UCMs
Comfigurator for HIO01
HIO01 can be configured using Comfigurator 3.11.10 minimum. This allows each of the 16 channels to be configured for the required function, eg ELV switch, Scene, Door contact, PIR, Window Contact, Make Up Room, Do Not Disturb, Keycard, Doorbell etc
A guide to Programming the HIO can be found in this forum
http://www.comfortforums.com/forum134/4587.html
 Posted: Sunday Dec 25th, 2016 12:56 pm
Examples of ELV switches that can be used with HIO
4 Gang switch gray (example)
3 gang switch, white (example)
2 Gang Switch, T&J Lavinia (example)
Schneider Zencelo Doorbell switch (example)
 Current time is 12:32 pm
