"Open door delay" doesn't seem to work
 Posted: Monday Oct 2nd, 2017 09:31 pm
Pharris15
I recently implemented a magnetic door latch, the unlatch command is "200, 49, 2, 50  255"
This should give a 2 second activation when I press 7 on the phone but I only get 0.5 second, changing the duration doesn't change the unlatch time.
Comfort 2 Ultra, V7.117
 Posted: Tuesday Oct 3rd, 2017 06:26 am
The open door delay works on the relay connected to the DM02
I would like to confirm that this is what you used and not other relays connected to outputs
 Posted: Tuesday Oct 3rd, 2017 11:28 am
Pharris15
Hi, yes I am using the relay on DM02, I use 7 on the keypad / phone to operate it.
 Posted: Tuesday Oct 3rd, 2017 05:23 pm
The response should be working
can you send your cclx file to support@cytech.biz so we can look at it
 Current time is 04:53 am
