Posted: Thursday Dec 6th, 2012 09:17 pm |
waynebr
Posts: | 89 |
Hi I have installed two fermax doorstations to the DM02's I find that sometimes I have to press the button two or 3 times before it rings the house phones, it only seems to happen if I haven't used the intercom for a while as after it has rung the phone once it appears fine.
Any ideas why it is doing this?
Posted: Friday Dec 7th, 2012 03:45 am |
Is it a case of the button not making contact?
Can you try to press the doorbell test button on the DM02 and see if this problem also occurs? If it also does, that means it is not a button contact problem
Posted: Friday Dec 7th, 2012 06:53 am |
waynebr
Posts: | 89 |
Hi the door button makes contact as I hear the keypad chime when pressed
Posted: Friday Dec 7th, 2012 07:08 am |
Do you mean the button on DM02 works every time but the Fermax button sometimes has to be pressed 2 ot 3 times?
That would indicate that there is a contact problem with the Fermax
Posted: Friday Dec 7th, 2012 07:10 am |
waynebr
Posts: | 89 |
Everytime it has happened the doorbell chimes on the keypad, but the phones do not always ring. don't think its a contact issue as the keypad chimes
Posted: Friday Dec 7th, 2012 10:40 am |
So the Button on the DM02 always rings the phones but the fermax button sometimes does not ring the phones bit always chimes on the keypad, is that correct?
Comfort may be ringing the phones but it may not be sounding
How many phones are connected? Try disconnecting all except pne
Posted: Friday Dec 7th, 2012 10:41 am |
waynebr
Posts: | 89 |
Thanks I have only one phone connected, I will recheck all the wiring and see how I get on.
Posted: Friday Dec 7th, 2012 02:37 pm |
waynebr
Posts: | 89 |
I think I might be closer to figuring out what is going on. If I press the intercom but then open the door it appears to cancel out the phone ringing. I have tried this by letting it ring a couple of times and then opening the door, the phone immediately stops ringing. Is this normal?
Posted: Friday Dec 7th, 2012 02:47 pm |
Yes that is a built in function
Opening the entry door stops the ringing
Presumably you do not need to answer the phone if you are already at the door
Posted: Friday Dec 7th, 2012 02:50 pm |
waynebr
Posts: | 89 |
Thanks, if by coincidence the back door rings but I open the front door will it still switch off. Can I disable this option in Comfort? I have the situation where the doorphones are outside and I have a porch, sometimes people will ring the intercom and then walk into the porch.
Posted: Saturday Dec 8th, 2012 02:09 am |
Yes if the back door station rings and you happen to open the front door before you answer the phone, that will cause the phone to stop ringing
It cannot be disabled. I think that small chance is a good tradeoff compared to opening the door and then having to answer the phone to stop the ringing, as the feature was introduced due to suggestions by users
You can still answer the door by User Menu 6 for door station even when the ringing has stopped
Posted: Saturday Dec 8th, 2012 07:48 am |
