Posted: Saturday Sep 22nd, 2012 12:18 pm |
strickers
Posts: | 78 |
I have a DP03 door station and the press button to activate the doorbell has stopped working. Everything else works fine. If I take off the cover and short the connections the doorbell sounds, so I guess its the switch that’s faulty. I am going to buy a new door station with a camera when I can afford it but for now could anyone supply me with a part number for a replacement switch? I assume I should be able to pick one up from RS components... Thanks,
Chris.
Posted: Sunday Sep 23rd, 2012 02:19 am |
I dont know what the farnell part number is, there may be many parts with slughtly different dimensions or specs
We will send some switches to Laser next week
Posted: Tuesday Sep 25th, 2012 09:03 am |
strickers
Posts: | 78 |
Thanks for your reply. Yes there are lots of different specs available.
What’s the process I need to follow to hold of them from Laser? Do I just call and ask or will they have a reference number
Thanks,
Chris.
Posted: Tuesday Sep 25th, 2012 12:05 pm |
Refer to this forum post and mention that some doorbell tact switches should be received from Cytech, but this would be probably late next week
Posted: Monday Oct 8th, 2012 01:31 pm |
strickers
Posts: | 78 |
Hi, I have been in touch with laser but they didnt get anything in the post. Can you please confirm you have sent the switch?
Posted: Monday Oct 8th, 2012 01:45 pm |
I understand they have just received the parts
Posted: Saturday Oct 20th, 2012 02:29 pm |
strickers
Posts: | 78 |
Hi ident,
Thank you for sorting out the switch. Really appreciate it. Unfortunately after replacing the switch it still has the same symptoms.
I had to splash out and purchase a new MA11P, DM02, MA71 and MA61. I think this will last a long time.
Just one question, where can I find fitting instructions? I cant find them on the Cytech web site.
I assume the dm02 sits with the main comfort board now?
Does it need a separate power supply as Laser didn’t add one to the order?
Thanks,
Chris.
Posted: Saturday Oct 20th, 2012 07:29 pm |
Posts: | 771 |
Where about's are you - we still carry limited spares for the old door stations NOTABLY SPEAKERS which fail every 18 months or so in exposed situations.
Posted: Sunday Oct 21st, 2012 01:58 am |
The manuals for the door station parts are in the DM02 manual, see http://www.cytech.biz/dm02_manual.html?category_id=108
You do not need a separate power supply if your door station is the non-camera type eg MA11. The ones with cameras require a separate 18V power supply TT1801/UK
The DM02 is mounted with the Comfort, and is connected by 5 wires to the MA11
Posted: Sunday Oct 21st, 2012 01:43 pm |
strickers
Posts: | 78 |
Hi, Thank you for your replies.
I cant find any specific instructions on what goes to where on the MA11P.
Can you please just confirm what should be wired where?
The connections I have on the ma11p are:
-, A, L+, L-, C, P1, P2, P3, P4, and 1,2,3,4
what should I connect to DM02?
Thanks in advance
Chris.
Posted: Monday Oct 22nd, 2012 12:51 am |
hendy
Posts: | 221 |
Here you go, extracted from DM02 manual:
MA11P DM02
- GND
A 12V OUT
L+ (NOT applicable)
L- (NOT applicable)
C GND
P4,P3,P2 (NO connection) (NOT applicable)
P1 BELL
1 SPK (To Door)
2 MIC (To Door)
3 12V OUT
4 GND
Posted: Monday Oct 22nd, 2012 02:13 am |
Posted: Sunday Oct 28th, 2012 02:01 pm |
strickers
Posts: | 78 |
Thank you both. All installed and working fine.
