Comfort Automation/ Security System Forums > Products > IRIO > ISM09 Submodule for PT100 Temperature Sensor
 Posted: Sunday Oct 23rd, 2022 03:04 am
The new ISM09 submodule which supports 4 PT100 temperature Sensors is now available. Only IRIO02 (with 4 Analog Outputs) supports this new submodule. IRIO01 (with 2 submodules) does not support ISM09 at this time.
PT100 is a standard Platinum Resistance Sensor which has a resistance of 100 ohms at 0 degrees. The ISM09 has 4 connections ofr PT100 sensors. Each PT100 can be mapped to a Sensor Register, with the values  in degrees C.
ISM09 is supplied without PT100, as these can be obtained from many suppliers,
ISM09 also includes 4 Digital outputs
See http://www.cytech.biz/product_details.php?item_id=551 for ISM  manual including ISM09
Comfigurator 3.13.8 is required for ISM09
 Current time is 09:23 am
