IRIO Website and Brochure
 Posted: Saturday Aug 21st, 2021 05:45 am
The new IRIO website is at http://www.cytech.biz/brochure/irio.html
There is a download link for the  brcohure
Attachment: IRIOwebsite.jpg (Downloaded 19 times)
 Posted: Monday Sep 2nd, 2024 09:05 am
Swiss-Toni
Just a quick question is this backwards compatible with the CP9000-ULT and is the LEM01B also backwards compatable
 Posted: Tuesday Sep 3rd, 2024 01:31 am
If you can upgrade CP9000 to the latest firmware then it is compatible with IRIO. LEM01B is more tricky as it has no EOL shunts. If you connect LEM01B to CM9000 thn you have to use double EOL resistors ie 4K7 in parallel wth the contact and 2K7 in series
 Posted: Tuesday Sep 3rd, 2024 08:01 am
Swiss-Toni
slychiu wrote: If you can upgrade CP9000 to the latest firmware then it is compatible with IRIO. LEM01B is more tricky as it has no EOL shunts. If you connect LEM01B to CM9000 thn you have to use double EOL resistors ie 4K7 in parallel wth the contact and 2K7 in series
What if no EOL are used in the circuit?
 Posted: Tuesday Sep 3rd, 2024 08:14 am
even if no eols are used, you have to connect the eol resistors, due to LEM02B not having the shunts to tell the system that EOL are not used.
 Current time is 09:21 am
