Comfort Automation/ Security System Forums > Products > IRIO > Can ISM06/ISM07 be used for 240v input?
 Posted: Thursday May 17th, 2018 09:08 pm
MDKKEN
Hi.
Can ISM06/ISM07 when given 240v input set flags or counters?
 If so how is done?
 Posted: Friday May 18th, 2018 03:16 am
ISM06 and ISM07 is able to  switch 240V as the relays are rated for 240VHowever they should not be used to switch 240V as it may not bbe sufficently speratwed from the low voltages on the IRIO
Please use IRIO-IO and RLE02 for mains switching
 Current time is 10:25 am
