Getting Started with Comfigurator
 Posted: Monday Jun 3rd, 2013 03:11 am
This is a quick guide to getting started with Comfigurator for programming Comfort
The manual "Programming with Comfigurator" can be downloaded from http://www.cytech.biz/programming_with_comfigurator.html
Click on Downloadable files to see the download
The Comfigurator software can be downloaded from http://www.cytech.biz/comfigurator.html
The latest Comfigurator version at this time is 3.9.5
See Connecting Comfort - a Quick Guide for instructions on connecting Comfort if you have not done so. http://www.comfortforums.com/forum16/3406.html
When you run Comfigurator, it will ask you to select the Default Template
A template is a default file for Comfort according to the model selected. The drop-down box above  will show the list of available models. Comfort II Ultra or Optimum will be the most used models. Check the Comfort model before selecting.
Press OK to confirm
Comfigurator will open with the chosen template settings
The left pane shows the programming categories, namely;
Configuration, Security, Security Type Settings, Telecoms, Control, Events, Schedule, Names.
Each of these categories has a + sign which opens up items in the category eg Events in the above screenshot
The middle pane shows the properties of the item selected in the left pane, eg in the above screenshot, the Configuration category items are shown
The status bar on the bottom of the screen shows
  1. the connection method (USB, Ethernet, or Rs232) and the communications address eg IP address/Port or USB serial number or COM port. The above screen shows Network (local) with IP address unassigned.
  2. Comfort Model (Ultra II in above screen)
  3. The vocabulary (English Residential shown above)  which is the language set for the voice menu
  4. File System (34 shown above) is a number corresponding to the model, eg Comfort II Ultra is associated with File system 34
Go to the following topics to continue this guide
Back to Programming with Comfigurator Index
http://www.comfortforums.com/forum128/4073.html
 Current time is 05:36 am
