How t connect TPB01
 Posted: Tuesday May 16th, 2017 02:12 am
caravanboy
Hi, this seems a daft question to ask... I'm nearing the end of my physical installation and I found a TPB01 in the box that I'd forgotten I'd ordered years ago. I've attached a photo. Due to the types of connectors it looked as though it was designed to clip on to the main Comfort board and then clip the existing TEL-IN connector on top?
I puzzled over it though and based on tracing the PCB I concluded that would invert the two wires (and I recall having phone line issues when that initially happened at my old house - without a TPB).
So, am I just being daft - which way am I supposed to connect this, or has the pre-installed connector in the photo been put on the wrong way around at the factory? It can't be clipped to the main board as-is or the components would hit the metal casing.
Swapping the connector around would be problematic as the screw-terminals seem to be biting-down on the trace that is only on the bottom face of the board.
Thanks.
Attachment: TPB01_Front.jpg (Downloaded 20 times)
 Posted: Tuesday May 16th, 2017 06:48 am
The correct orientation of the connector for TPB02  is shown below
The terminal block  must have been plugged in incorrectly
Attachment: tpb01.jpg (Downloaded 19 times)
 Posted: Tuesday May 16th, 2017 07:42 am
The TPB02 can also be mounted vertically
Attachment: tpb02 plguin small.jpg (Downloaded 19 times)
 Posted: Tuesday May 16th, 2017 07:43 am
TPB01 (old model) is straight, see below
 Posted: Tuesday May 16th, 2017 11:51 am
caravanboy
Great, thanks. So I have a TPB02 (despite the order and box being labelled TPB01). I'll have to make sure it still makes contact with the circuit traces but I've re-viewed the rear of the circuit and my comment about the lines crossing over seems to be wrong. It must have been getting late when I concluded that :)
 Current time is 06:01 pm
