S12V (Aux) behaviour
 Posted: Monday Apr 7th, 2008 02:50 pm
I have a response to switch the aux 12v power to latched smoke detectors attached to the Security Off response. After a smoke alarm, disarming the system does not reset the latches. However I can reset them by setting to AWAY mode and disarming. Why?
Answer
S12V is normally on (supplying 12V) to smoke detectors and other similar types
The S12V  is not reset when the system is disarmed, otherwise you would not be able to find out which detector out of others in the house which caused the alarm.
This S12V output can be  pulsed off and on using an action when the system is armed to reset smoke detectors which are latched ie they may have an LED which turns on when the detector is activated and remains on until power is removed
 Current time is 09:37 am
