Automation Contrrol when arming or Disarming the Securty System
 Posted: Sunday Sep 6th, 2020 05:18 am
When the security system is armed to any mode ie Away, Night, or Day Mode, or when the system is disarmed to Security Off Mode, it is possible to execute a Response to control any device that is connected to the system.
In Comfigurator 3.13.5 and above, go to Alarns > Partition Events as shown below.
Assign a Response to Security Off, Away Mode, Night Mode or Day Mode for each Partition. Comfort has up to 4 partitions. Partition 0 is used for Non-partitioned systems
For example, in Away ode, you can switch off all lights and appliances, or in Night Mode switch off downstairs lights, but switch on the outside light. For Security Mode, you could turn on lights and appliances. The possibilities are endless.
Note that this is NOT just for Partitioned systems. Even if the system is not partitioned, the Security Off, Away, Night, Day Mode Responses must be programmed here
Note: Security Off, Away, Night, Day Mode Responses  were previously in Events > Miscellaneous Events in older versions of Comfigurator prior to 3.13.5
 Current time is 01:05 pm
