Keypad Sign-in User Responses
 Posted: Thursday Apr 23rd, 2020 02:59 am
This feature applicable in Comfort Firmware 7.175 allows sign in on the keypad for any specified user to activate a User Response, which may be programmed for any purpose, for example to unlock a door, turn on lights or appliances
The screen for Misc Events > User Responses is shown below
an example of a user response is below
The response is programmed to open the door, turn on lighrs and the photocopier machine if User 1 signs in.
The action Skip Annoucement has a different function when used in User Responses. It causes the keypad to exit without going on to the user menu eg "Welcome, Security off.. etc"Hence the keypad when signed in by a specirfic user will triiger the programmed user responses only and will bto go to user menu  as usual. This allows the keypad to be used for access control
see http://www.comfortforums.com/view_topic.php?id=5161&forum_id=79&jump_to=24912#p24912 for Comfort 7175 firmware
 Current time is 11:55 am
