Control Menu Programming Simplified
 Posted: Sunday Apr 30th, 2017 06:11 am
If the Voice menu is not needed, programming the Control menu for the iOS or Android apps can be  simplified. This also applies to LGX01 Logic Engine and UCM/Logic which does not have a Voice Menu
This applies to Comfigurator 3.11.13 and Comfort firmware 7.116 or above
Instead of selecting words from the word list, enter any text in Alternative Phrases in Control Group, Control Key and Control Action. Leave out the Phrase words.
The Control groups will appear according to the text in Alternative Phrases
In Control key, if the feedback is defined as Outputs, Inputs/Zones, Flags, the Control Actions  automatically become 0 for Off, 1 for On
Above example of Output Feedback. Note that OFF and ON are added automatically
The Output ON and OFF Responses do NOT need to be entered. Off will automatically set the feedback Output OFF, ON will automatically set the feedback Output ON, ie Output 1 in this example
Above example of Flag Feedback. Note that OFF and ON are added automatically
The OFF and ON Responses do not have to be created; Off will automatically set the feedback Flag OFF, ON will set Flag On
Above example of Zone Feedback. Note that OFF and ON are added automatically
However in this case OFF and ON Responses are not created automatically. Off and On responses for Zone feedback must be created manually.
Counter Feedback is different
When Counter is used in Feedback, there are no Off or ON responses created.
In the Comfort app, a slider will be seen when the Feedback is a counter. Changing the position of the slider sets the value of 0 to 255 into the assigned counter
 Current time is 02:19 am
