A major improvement in Comfigurator 3.11.12 is the ability to change the values of Counters, Sensors, Outputs, and Flags from Comfigurator. This is a great help when testing programs especially for IRIO, UCMs like KNX, Cbus, Modbus, Zwave which are based on mapping to Counters, Flags, Sensors and Outputs.
For Counters go to Events > Counters and select a Counter
check the "Show Status" box
The current value of the selected Counter is seen
Enter a new value from 0 to 255 in the box. This changes the value of the counter immediately.
Note that changing the value of a counter from the UCM like this will also trigger the maped Counter Response
Also see topic on Use of Counters in http://www.comfortforums.com/view_topic.php?id=4655&forum_id=128&jump_to=21977#p21977
For Flags go to Names > Flags and select a Flag
The current value of the selected Flag is seen as On or Off. In fact all flags status is seen
Click on the On or Off status to toggle it. This changes the value of he flag from On to Off or vice versa
For Output go to Names > Outputs and select an Output
The current value of the selected Output is seen as On or Off. In fact all Output status is seen
Click on the On or Off status to toggle it. This changes the value of ehe Output from On to Off or vice versa
For Sensors go to Events > Sensors and select a Sensor
The current value of the selected Sensor is seen
Enter a new value from 0 to 255 in the box. This changes the value of the Sensor immediately.
Note that changing the value of a Sensor from the UCM like this will also trigger the mapped Sensor Response
Another very useful feature is the Register Monitor, where you can select Counters, Sensors, Flags, Zone/Inputs , Oututs to monitor in the same window
For details, see http://www.comfortforums.com/forum20/5149.html
