Holidays in Time Programs and Reminders
24 Holidays can be defined for the year. If a Time Program Day of week is ON for Holidays, it will be active on any of the defined Holidays. The application for this is when things should happen at a different time from normal days, for example when a shop opens later or closes earlier.
If a Time Program is set for days of week say Monday to Friday but not for Holiday, and a particular day is a Holiday (as defined in the Holidays table), the Time Program will be active on that day. If it is required that the Time Program/ Reminder should not be active on a Holiday then in the Time Program Response, the action code sequence
If Holiday <> 0 Then
Exit Response
should be used to bypass the Response on holidays
eg
To define Holidays, go to Schedule > Holidays.
For each of the 24 holidays, a Month and Day can be specified. These holiday definitions are used for Time Programs and Reminder Messages.
