CM9001-ULT has 4 Alarm Partitions with 16 users. See the technical specifications for CM9001-ULT here http://www.cytech.biz/brochure/CM9001-ULT.html
The new model CM9001-EX has 8 partitions with 99 users. This is designed for larger offices and commercial properties. The Office Vocabulary is installed by dwfault instead of Residential. See the detailed specs here http://www.cytech.biz/brochure/CM9001-EX.html
In Comfigurator, select File > New > CM9001-EX
The hardware is exactly the same as the other CM9001 Models. Only the Firmware, File System, and Vocabulary is different.
The Technical Specifaction for CM9001-EX is attached
Attachment: Cytech CM9001-EX - Product Specification.pdf (Downloaded 8 times) Last edited on Sunday Mar 28th, 2021 09:25 am by slychiu
