Siren Types
 Posted: Wednesday Nov 13th, 2019 03:03 am
Comfort has 20 programmable Siren Types
The siren Types can be asigned to Alarm Types as shown below. For example the Intruder Alarm Type has Siren Type called "Intruder"
The Intruder Siren Type has the properties below
  • Duration is duration in seconds for the siren eg 300 means 5 minutes
  • Sound Type is one of the sound Types which gives the sound characterictic
  • Door Phone is checked if siren is heard in the Door station
  • Keypad is checked if the siren is heard on the keypads
  • High level means the Speaker output level is maximum and is not affected by the triimer on Comfort
  • Bell output is checked if the Siren is heard on the Bell (Siren)
  • Permanent means the duration is permanent This overrides the Duration
In normal cases it is advised not to alter the settings
 Posted: Wednesday Nov 13th, 2019 03:11 am
Non-Alarm Siren Types
Some of the Siren Types are not assigned to Alarms
  • Arming Siren Type 3 - This is heard when the system is arming during exit
  • Arm Trouble (Not Ready) Siren Type 4 - This occurs during arming when there are pen zones
  • Away Armed Siren Type 4 - This is heard when system is armed to Away mode. This is by default 2 chiros on the external siren
  • Short Trouble Siren Type 5 - Thi sis heard when there is any Trouble alarm eg RS485 Comms fail, Power failure, Battery, Phone trouble, Zone Trouble
  • Doorbell - This is heard when the doorbell is pressed
  • Night Armed Siren Type 16 - This sis heard when system is armed to Night Mode
  • Night Arming Siiren Type 18 - This is heard during delay while arming to Night mode
The Sound Types, duration etc can be programmed for these ziren tyoes
 Current time is 05:31 pm
