Posted: Wednesday Jul 10th, 2019 01:15 pm |
theshepherdmatt
Posts: | 30 |
Hi all,
I believe it's possible to add 2 window contacts to a single zone, I presume that they are just wired together in the terminal block? is there something i need to do via comfigurator
Many thanks
Posted: Wednesday Jul 10th, 2019 01:42 pm |
Posts: | 5495 |
2 or more window contacts should be wired in series, so that if any window contact is open then the zone will detect as Open
If you do not use End of line resistors then the wiring is simple. If you do use EOL resistors then they should be wired so that the series resistor 2K2 is in series,m and the 4K7 resistor is in parallel wth the combined series contact
Posted: Wednesday Jul 10th, 2019 01:47 pm |
theshepherdmatt
Posts: | 30 |
Thanks,
i'm a complete novice, I just googled how to wire in a series.
Cheers
