Assign monitoring keypad for baby monitor
 Posted: Monday Jun 30th, 2014 05:29 pm
lms
I know that a monitored keypad can be assigned in a keypad response, but is it possible to assign a monitoring keypad for the baby monitoring function in a response?
For example, on some specified event (not necessarily on a zone input), I need to turn on the speaker on keypad 1 and the microphone on keypad2 in order to monitor keypad2 from keypad1. I also need to be able to change both the monitoring and monitored keypads within responses based on specified events.
I know this can be done via the keypad menu, but this is too complex for the specific requirement. I'd prefer to completely automate this but would settle with separate switches perhaps connected to RIO inputs.
 Posted: Monday Jun 30th, 2014 06:09 pm
The baby monitor Response needs to be activated by a keypad function key
The F key is like a shortcut key that turns on the keypad so that it is active
Running it by Response would not activate any keypad so you could not hear the baby monitor on any keypad
 Posted: Monday Jun 30th, 2014 06:11 pm
lms
Hi ident: Just what I thought. Thanks for your prompt reply.
 Current time is 05:59 pm
