Programming a Zone to announce
 Posted: Monday Jul 31st, 2006 01:17 pm
A zone can be programmed to announce on the keypads whenever it is triggered. This is not referring to Walk test, which is a test mode in which all zones are announced when triggered.
To program a zone to announce, Assign a Response with action Say ZoneName in the Zone Response (using Response Wizard in Comfigurator)
The Zone Response is activated whenever the zone is triggered (eg door open or Movement detected). The Say Zone Name action will cause the programmed zone name to be announced
The Response can be smarter, eg it can announce only at certain times
eg
If Hours >= 7 And Hours < 22 Then
    Say ZoneName
End If
An example file is attached
Zone 1 will will announce when open
Zone 2 will announce only from 7 AM to before 10 PM
This will announce the zone only between 8 PM and 6 AM
Comfort Responses has powerful conditional programming to allow for almost any situation
Attachment: announcezone.zip (Downloaded 18 times)
 Posted: Sunday Aug 4th, 2013 03:04 am
Comfigurator 3.6.x Zone Settings has an "Announce" Checkbox
When checked this zone will anounce its own name when the zone is opened
This requires Comfort firmware 7.009 and above
The action announce zone is needed only for conditional announcements
 Current time is 12:13 pm
