Posted: Sunday Jun 23rd, 2019 08:48 pm |
theshepherdmatt
Posts: | 30 |
Hello,
I've just recently moved into a house that is fitted with C-bus and Comfort, c-bus is up and running no problem but the comfort system hasn't worked for years.
This is my setup
PC01-050B (1) and PC01-051B (1)UTL 5.113RS232 UCM 5.92 (PC01-017E)
From what i can tell is that it is still possible to update the UTL as its 5.113 (anything less and it wouldn't be possible) is that correct?
I have ordered a Eht03 UCM to replace the old RS232.
Am I flogging a dead horse or is it possible to update the firmware and start over?
Any advice will be much appreciated.
cheers
Posted: Monday Jun 24th, 2019 02:20 am |
Posts: | 5498 |
The UCM 5.92 must be replaced not just ETH03. UCM 5.92 cannot be upgraded
The plug-in MPU01 is no longer produced. I dont inow if laser has stock. look at http://www.laser.com
Posted: Monday Jun 24th, 2019 10:55 am |
Posts: | 771 |
I have a plug-in MPU01
You may be able to extract the program file - but unless you are just playing with it i would only use this to get information.
I think program form scratch much safer.
[highlight= rgb(205, 214, 224);][size=We have resurrected and upgraded many Comfort units.]
If all you ant is an alarm then the existing comfort set up should be fine. The Eth03 will only be any good if you are looking at permanently connecting to Ethernet. It on its own does not provide remote access.
I canot see a CBUS UCM listed so again if you want to connect to CBUS then you may need the new CBUS UCM which then would ideally require an upgrade.
Have also been dealing with CBUS for many years so any questions welcome
Posted: Monday Jun 24th, 2019 12:07 pm |
theshepherdmatt
Posts: | 30 |
Hi thanks for the reply,
After further inspection it appears that i already have an MPU01 connected with 5.113 firmware. Unfortunately i don't know any of the engineer codes? I want to flash new firmware and start again....
whats the best way forward?
cheers
Posted: Monday Jun 24th, 2019 01:25 pm |
Posts: | 5498 |
The MPU can be removed and replaced with a new one (if the contacts in the sockets are still good)
Try the default engineer code 6789. If that does not work then you may have a problem
Posted: Monday Jun 24th, 2019 01:41 pm |
Posted: Monday Jun 24th, 2019 02:13 pm |
theshepherdmatt
Posts: | 30 |
Man!!! i just paid £130 for a new eth03 module.....
Posted: Monday Jun 24th, 2019 09:02 pm |
theshepherdmatt
Posts: | 30 |
Hello,
I've managed to update the MPU with the latest ULTRA firmware 7.153 from 5.113 but i still cannot get the eth03/UCM connected. The eth03 is discoverable with CS and all ports are open.
Unfortunately i don't know the engineer code? i've tried 1234 and 6789 but cannot connect comfigurator to the UCM.
Can you advise if possible?
Many thanks
Posted: Tuesday Jun 25th, 2019 01:31 am |
Posts: | 5498 |
You can buy a blank U4 EEPROM from Llaser to replace the programmed one in the Comfort. This is unprogrammed and will have a default 1234 user code and default engineer code.
Posted: Tuesday Jun 25th, 2019 06:52 am |
Posted: Tuesday Jun 25th, 2019 01:14 pm |
Posts: | 771 |
OR there may be a spare U4 in the read write slot of the UCM?
A
Posted: Tuesday Jun 25th, 2019 01:40 pm |
Posted: Tuesday Jun 25th, 2019 01:45 pm |
Posts: | 5498 |
The sockets are empty. The early ucms did not come with spare eeproms
Posted: Tuesday Jun 25th, 2019 01:49 pm |
theshepherdmatt
Posts: | 30 |
I dont suppose you have a spare MPU laying around that you would like to sell do you? I know laser sell them but I'd rather get a second hand one as I still don't know if my PCB actually works?
Posted: Tuesday Jun 25th, 2019 02:18 pm |
Posts: | 5498 |
I thought you managed to upgrade your mpu to version 7?
Posted: Tuesday Jun 25th, 2019 02:28 pm |
theshepherdmatt
Posts: | 30 |
Yes I did, but cannot connect to UCM as I don't have login codes. I'd like to wipe the MPU and start again but with the login it's just not happening..
Posted: Tuesday Jun 25th, 2019 02:31 pm |
17th Post |
theshepherdmatt
Posts: | 30 |
Also I wanted to try and extract the old program files from the old UCM, but again it won't work without the login/engineer code. Being a security system there doesn't seem to be a 'back door' way in but that's to be expected.
Posted: Tuesday Jun 25th, 2019 02:37 pm |
18th Post |
Posts: | 5498 |
I don't know if you mean the u4 eeprom or the mpuThe firmware is in the mpu If you have upgraded to version 7 then you don't need a new one. The program configuration is in the u4 eeprom. If you have lost the engineer code then you need a new u4, not an mpu
Posted: Tuesday Jun 25th, 2019 02:54 pm |
19th Post |
Posted: Wednesday Jun 26th, 2019 07:04 am |
20th Post |
Posts: | 5498 |
It is not clear from the photo if the U4 Socket is emoty or there is an IC inserted
Current time is 02:15 am | Page: 1 2 |
