Hi Chris,
How many Input/Zones do you need?
There are 3 types of LEMs:
1. LEM01-M2 has 8 inputs and 8 outputs.
2. LEM02-M2 has 8 inputs with no outputs. This is the same as the LEM01-M2 without the OP01 output drive module. The LEM02-M2 can be transformed into the LEM01-M2 by plugging in a OP01.
3. LEM03 has 16 inputs and no outputs. With the LEM03 connected to Comfort, no Slaves can be added, because the inputs 17 to 24 are the same as the Slave's. Thus the total capacity of the system becomes 24 inputs and 8 outputs.
Since LEM03 only have 16 Inputs without any outputs. I suggest you change the LEM03 to LEM02 if you need a slave or more.
Thanks,
YuanchangLast edited on Wednesday Oct 14th, 2015 09:27 am by yuanchang
