panic button & IRR & CWM
 Posted: Wednesday Jun 24th, 2015 09:16 am
Elmotamared
At " How to Configure a Comfort System " PDF :
1- in sizing of comfort system...for airconditions control,why we won't buy ir reciever (IRR) to recieve  ir signals from remote controls and save them in the comfort system ?
2- what are the connections and how to control panic button?
3- CWM, is it available now or not? what's new about it ?
4- I don't understand the power point control well .. what's it in some more details ? Is it like dimmer ?
thanks in advanced
 Posted: Wednesday Jun 24th, 2015 09:37 am
IRR01 receives Comfort IR signals from RC01 to trigger Responses in ComfortIt cannot be used to learn IR signals. You can only learn IR signals using the UCM and send the learned IR signals through any output via IR01W , IR03W or IRM01
Panic button is an on/off switch and is conected to any zone programmed as Zone Type Panic
CWM is obsolete. You can use Comfort apps with UCM/ETH03 for control by wifi or internet
That was using X10 modules. X10 is obsolete and is old technologyModern 3rd part dimmers use eg C-Bus and KNX
The document needs to be updated as it is quite old
 Posted: Wednesday Jun 24th, 2015 10:12 am
Elmotamared
thanks
for IRR , the comfort ultra contain a built-in IRR or i must get one if i bought RC01 to fully control with it ?
to control system from outside the home i will give the system fixed ip and while there is internet at home,i can control it ...is that correct?
please tell me in some more details
where i can get the updated data for training and knowing everything about comfort like installing,wiring and programming...etc ??
 Posted: Wednesday Jun 24th, 2015 10:29 am
IRR is a separate component that mus be purchasedIt must be conected to RIO01 not to Comfort
 Current time is 10:25 am
