Posted: Friday Aug 30th, 2013 08:55 am |
tonyc
Posts: | 2 |
I am in the process of cabling my house but i am unsure which cable you reccomend for shielded cat5. The wiring schematic has got cat5e FTP, but in other areas it reccomends cat5e stp. The stp seems very expensive to. Can you tell me which is best please.
Tony
Posted: Friday Aug 30th, 2013 11:27 am |
Vangelis
Posts: | 138 |
Assumption is that this question is related to Comfort and not generic...
The keypads require STP connections but you can get away with non-shielded when connecting to say UCM/ETH2
For data runs round your house then standard Cat5e is good enough - rule of thumb is to try and keep clear of any mains cabling.
Vangelis
Posted: Friday Aug 30th, 2013 12:39 pm |
tonyc
Posts: | 2 |
Sorry yes it was with regards to the comfort panels. I am upgrading the existing system after some major faults and we have had a new extesoon built so now is a good time to change. Would FTP cable be ok for keypads ect & just use utp for networking also part of the existing alarm cable is six core would I need to change these. One other thing is external pir's I presume should be home run individually back to node zero. Thanks for your help
Tony
Posted: Friday Aug 30th, 2013 12:49 pm |
Vangelis's recommendations are correct
Would FTP cable be ok for keypads Yes
Yes UTP for the nonkeypad modules
No, 6 or 8 alarm core is preferable to CAT5 for alarm cables. They are multistranded so dont tend to break so easily and they dont need the properties of CAT5
Yes
Posted: Saturday Aug 31st, 2013 11:19 am |
Posts: | 771 |
You will find that a reel of screened 6 core alarm cable is far more cost effective - you will probably be able to purchase 50m.
