RESISTORS
 Posted: Sunday Jan 8th, 2012 10:55 am
radawodu1945
I would like to know if a 12V smoke detector
can be compatible with a 24V output fire alarm system,
if not, can resistors be used to acheive this.
Thanks for your help.
 Posted: Sunday Jan 8th, 2012 11:28 am
bs85
The Comfort system is 12v so you could connect your 12v smoke detector to it.
 Posted: Sunday Jan 8th, 2012 01:16 pm
tech07
You should not even try to connect a 12V smoke alarm to a 24V fire alarm system
There is the liability and danger if it does not work. You should use the recommended sensors for the system
 Posted: Monday Dec 10th, 2012 03:49 pm
pavel
The smoke detector only gives an output when it detects smoke and the output can be fed to any output system. If I’m not wrong the smoke detector has 6 pins, you just need to figure out the right combination. The 24V fire alarm system has an output alarm that requires this high input voltage. I believe the output from the sensor can work with it. Only try this if you have an understanding of smoke sensor circuitry though.
prototype pcb assembly
 Posted: Tuesday Dec 11th, 2012 01:14 pm
wiredhome
a 12v detector is for 12v systems
so if you connect it to 24v it will blowup!
 Current time is 07:48 pm
