Control Not working on iPhone App
 Posted: Saturday Mar 31st, 2018 12:41 am
simond
Help! I'm having problems with control functions from the iOS app.
Using Comfigurator - V3.12.3.0 and iOS App v1.3.1 (34) - System running 7.117 and Eth UCM running 7.098.
Download latest config successful to system and it resets... put the CCLX file through the conversation tool, open it on the iPhone and import into the iOS Comfort app.
I can log into the app, change security mode and it reports correct variables (e.g. zones open etc) however control features simply wont work... any ideas?
Cheers
Simon
 Posted: Saturday Mar 31st, 2018 01:00 am
simond
In addition - I can execute the responses successfully via comfigurator GUI... e.g. I can click 'execute response' and it works fine... only via the App it doesn't work...
 Posted: Saturday Mar 31st, 2018 12:03 pm
Do all the control menu feedback work?
Please send your cclx file to support@cytech.biz so we can see what is being controlled
 Posted: Saturday Mar 31st, 2018 12:41 pm
simond
Thanks Slychiu
In the control menu there are variables reported (e.g. temperatures) and these show up correctly & accurately in the app. However, feedback such as toggles don't work, e.g. if you change a toggle switch (lights) for example it immediately switches back again.
CCLX on its way!
 Posted: Saturday Mar 31st, 2018 03:01 pm
strickers
What device are you using for your lights? (cbus,velbus etc) I had a similar issue and had to use a counter response for velbus to make it use 0-255
 Posted: Saturday Mar 31st, 2018 03:22 pm
simond
Thanks Strickers - the are a number of things controlled via the control menu, including CBus, Heatmiser, Relays, etc... the control menu works via the keypad but not via the iOS map. Via the iOS app the control menu reports variables (like temperatures from the heatmiser stats) but none of the control actions actually work...
Chui looking at it - already found some mistakes in my control menu settings where I converted from X10 to CBus and left some of the old X10 feedback in... but not cleared it sadly...
 Current time is 05:30 pm
