Comfort iPhone App 1.2
 Posted: Tuesday Jun 13th, 2017 04:47 pm
The new 1.2 version of the Comfort iOS app has been released
For new users, look for Cytech Comfort in the Appstore
Bugs
  • Saved User code does not work for Local Connection 2
  • Logging in to 2nd port eg 1002 actually logs into the 1st port eg 1001 so the 2nd port is not being used
Changes are
  • Selectable 2 ports for Local and 2 ports for Remote on the log in page so if one  port is busy, the other port can be selected quickly
  • Added user-selectable Icons for Control appliances with status change
  • Removed click sounds when control button is pressed
Press Edit to change the icon for the control item
Press Set Icon next to the control Item
Select the Icon and press Done
 Posted: Monday Jun 19th, 2017 02:43 pm
srooks
Thanks for this.
Can you give some guidance on how to achieve the switch (Porch Light) and dim controls.
 Posted: Monday Jun 19th, 2017 03:36 pm
The control page is based on the programming in the Control Menu in Comfigurator
To get the On/off feedback and control the Feedback Type in Control menu must be a binary type, eg Flag, Zone, Output
To get a slider feedback/control, the feedback type must be a Counter with no control actions
More details can be found at
http://www.comfortforums.com/forum122/4007.html
The app version 1.2 does not change any programming of the control menu - what has changed in the ability to select icons which represent the status
 Current time is 06:27 pm
