Posted: Thursday Nov 20th, 2014 09:29 am |
Posts: | 5498 |
Version 1.1 of the iPhone app has been published
The changes are
- When the app is first installed, a default profile is created. Without any profile, the app will crash when you tap on the email attachment with the converted JRLCCIP file and select "Open in Comfort"
- The slider on the Control menu mapped to Counter feedback is now working. The position of the slider sends the value 0 to 255 to the mapped counter, and any change in the counter value in Comfort also updates the position of the slider. This feature also requires Comfort firmware 7.067 (currently beta see http://www.comfortforums.com/forum79/4045.html )
Posted: Saturday Nov 22nd, 2014 12:18 pm |
Howser
slychiu wrote: - The slider on the Control menu mapped to Counter feedback is now working. The position of the slider sends the value 0 to 255 to the mapped counter, and any change in the counter value in Comfort also updates the position of the slider. This feature also requires Comfort firmware 7.067 (currently beta see http://www.comfortforums.com/forum79/4045.html )
Any chance of expressing the values in percentages?
Posted: Saturday Nov 22nd, 2014 03:15 pm |
CytechMartin
Posts: | 47 |
No, 255 means 100%, 0 means 0%
Posted: Saturday Nov 22nd, 2014 04:45 pm |
Howser
I know that. It might make more sense for end users, especially for dimming and the likes.
Just a thought.
Posted: Sunday Nov 23rd, 2014 05:55 am |
Posts: | 5498 |
There are some systems like Zwave where the counter values are 0 to 99 for dimming levels and 255 for on
Expressing the values as % in this case would be misleading as 99 would be only 40%
I think seeing the slider position should give a good indication of the percentage of full scale
Posted: Sunday Nov 23rd, 2014 10:00 am |
Howser
slychiu wrote: There are some systems like Zwave where the counter values are 0 to 99 for dimming levels and 255 for on
I was thinking of Clipsal who converts the HEX value into percentage. PICED does this quite well (and provides a formula as well). Expressing the converted value (instead of the actual value as in Zwave) might be beneficial to those that are not HEX inclined.
Posted: Sunday Nov 23rd, 2014 10:21 am |
Posts: | 5498 |
For zwave this means that 50% ie value of 50 would be converted to 50/255 = 18% instead of 50%
Clipsal just has to work with CBus, comfort has to work with many diffrent systems
Posted: Sunday Nov 23rd, 2014 11:17 am |
Howser
slychiu wrote: For zwave this means that 50% ie value of 50 would be converted to 50/255 = 18% instead of 50%
The Zwave concept is totally flawed, hence why I mentioned how Clipsal does the conversion.
slychiu wrote:Clipsal just has to work with CBus, comfort has to work with many diffrent systems
I was suggesting representing Counter values (Comfort values) in the iPhone App (Comfort app), this is a Comfort App representing Comfort values, no other system is in play here, or am I missing something?
Posted: Sunday Nov 23rd, 2014 12:23 pm |
Posts: | 5498 |
Counters can be mapped to Zwave, Cbus, KNX and many other systems, not just to counters in isolation from other systems
Posted: Sunday Nov 23rd, 2014 01:18 pm |
Howser
What I was suggesting was presenting the counter value in percentages within the iPhone app to the end user. This would be a display only attribute, which would not influence what is mapped to the counter.
Posted: Tuesday Nov 25th, 2014 02:30 pm |
Posts: | 1200 |
Version 1.1 of the iPad app has been publishedThe changes are the same as iPhone app 1.1- When the app is first installed, a default profile is created. Without any profile, the app will crash when you tap on the email attachment with the converted JRLCCIP file and select "Open in Comfort"
Posted: Tuesday May 26th, 2015 09:39 pm |
darnold
Posts: | 20 |
I am now using the 2nd Generation app. While it logins to my system and tells me the state of the system I do not get any zone information nor do I get any home control functions?
Posted: Wednesday May 27th, 2015 12:33 am |
Try uninstalling and reinstalling. That worked for me whereas upgrading over the top of the old one didn't and produced similar issues to what you are having.
Posted: Wednesday May 27th, 2015 02:42 am |
darnold
Posts: | 20 |
Nope, uninstalling and reinstalling didn't resolve the issue.
Posted: Wednesday May 27th, 2015 04:38 am |
CytechMartin
Posts: | 47 |
I suspect that the attachment is not loaded correctly as you even can't see control menu or zones, could you try to close the app from backstage first, then re-load the attachment.
Please refer here for more information
http://www.comfortforums.com/forum122/4007.html
Posted: Wednesday May 27th, 2015 06:45 am |
Posts: | 5498 |
The 2nd generation app requires you to receive the email attachment with your converted file. It will not be carrried over from the 1st generation app, as both apps can co-exist on your phoneIf you have not done this, the zones and control menu are not present
Also close the app so it does not run in the background before tapping on the attttachment
Posted: Wednesday May 27th, 2015 11:55 am |
17th Post |
darnold
Posts: | 20 |
I started from scratch and its now working, thanks.
