Android Phone App 1.04
 Posted: Sunday Sep 23rd, 2012 02:43 am
The new beta version of the Phone app can be downloaded from
http://www.cytech.biz/android_app.html?category_id=98
This fixes bugs that were in the previous versions
  1. Back Button did not exit the application
  2. When the app was in the Control Page, and it times out (2 minutes) and another app is started, going back to the app seems to show it is logged in but it is not.
  3. Away, Night, Day buttons stop blinking when you go to the Control Page and back
  4. Sounds obey media volume settings
 Posted: Sunday Sep 23rd, 2012 10:18 pm
wexfordman
Hi ident
Have installed the most recent version and still seem to be having probd
When trying to log in I keep getti.g connection tmeouts! Also I Di.d when I do manage to log in it still takes a very long time to get status of devices etc!
Eamon
 Posted: Tuesday Sep 25th, 2012 11:25 am
wexfordman
Hi ident, just to give an example, it took over 60 secs to get scs temp readings to display on my android app just now. This was connecting locally by wifi.
Regards,
Eamon
 Posted: Sunday Sep 30th, 2012 06:00 am
Thanks for the feedback, we are still working on improvements to the android apps
 Posted: Sunday Dec 2nd, 2012 11:42 am
waynebr
HI I have downloaded a copy of this to try on my phone, I can get it to connect and to open, but I cannot get the file to load the configuration, I have it emailed to my phone and click view on Gmail as that is the only option it gives, It them lets me select the option in the App but does not load the details into the app.
I am using Gmail, Samsung Galaxy S2 with Android 4.0.4. Should this work fine? I know from earlier versions that the newer androids where not supported but I thought they where now.
 Posted: Sunday Dec 2nd, 2012 01:07 pm
The important thing is to read the email using an email (gmail in your case) client and not by webmail. Using webmail you will not be able to load the attachment
 Posted: Monday Dec 3rd, 2012 07:41 am
waynebr
HI Thanks,I am using Gmail and not Webmail, the options in Gmail are View or Save, I click View and it asks me to select the App setting to use. I select my Comfort setting and then it confirms that it was selected, the email then stays in the foreground and nothing else happens.
 Posted: Monday Dec 3rd, 2012 07:57 am
waynebr
Just an update, I tried it with the android email client using a different email address and it has worked, it may be an issue with how GMAIL reads the file. it dosn't confirm that it has loaded the file but I selected the file and the location, then went to the Comfort app, logged in and it was working
 Posted: Monday Dec 3rd, 2012 11:39 am
There should be a dialog asking you to select the configuration eg Home or Ooffice or another name
Can you see if the zones in the zones page showing the names that you programmed in the cclx file
eg
That shows that the cclx file has been imported
 Posted: Monday Dec 3rd, 2012 04:32 pm
waynebr
Hi I am away for a couple of days and will check when i get back. I Know I was able to see some home controls after a few attempts at loading the file so it must have loaded. I guess that as you progress thr app then it will be easier to load. Would be great to have a import functiion in the app or feedback as to progress and when it has loaded
 Current time is 12:35 pm
