Posted: Thursday Jul 19th, 2012 01:40 pm |
Posts: | 1200 |
The new version of the Android app is ready for testing, in the attached apk file
Send this into your mobile device and click to install. It will replace the previous version but will not delete any data
The changes are- Fixed an issue where the Security Mode status was not updated after logging in when the system is large
- App will log out and go back to the login page when screen times out or another app is active or the standby button is pressed.
- Fixed problem where if wifi is out of range there was no indication. Now it will log out.
- Fixed a number of bugs
Known Issues- Cameras do not work
- back key still has problems
- after wrong code is entered, correct code does not work for about 20 seconds
The apk file and quick start instructions can be downloaded from http://www.cytech.biz/product_details.php?item_id=373 Last edited on Sunday Aug 19th, 2012 02:41 am by
Posted: Thursday Jul 19th, 2012 04:34 pm |
wexfordman
Posts: | 546 |
Cool :-)
Are we looking at android phone app soon ?
Posted: Friday Jul 20th, 2012 02:40 am |
Posts: | 1200 |
That will be the next after we get this out
Posted: Friday Jul 20th, 2012 11:09 am |
Tan121
Posts: | 23 |
The app (last version) did not work with HTC Desire Android 2.3, but With HTC ONE Android 4.0 it works fine. And if you have a bit bigger screen then it absolutely enough to use the tablet app.
One sugestion: Zone open and closed images are misleading. If the zone is closed you see red cross. Red cross is like an error. But if the zones are closed, then everything is ok. So maybe you think about the icons and change them. Closed zone should not be red but green in my opinion.
One more thing. I see zones that I am not using. Is it possible to hide not used zones?
Posted: Friday Jul 20th, 2012 11:34 am |
You mean that 1.82 did not work on Android 2.3?
Do you mean that it did not install? What error message did you see?
We will consider colours
Posted: Friday Jul 20th, 2012 01:14 pm |
We have tested 1.8.2 on Samsung Galaxy S2 phone with Android 2.3.3. It worked OK
Posted: Saturday Jul 21st, 2012 10:33 am |
Posts: | 557 |
What is the minimum space required for the installation? My phone doesn't have enough. Can the App not be installed on the SD card?
Posted: Saturday Jul 21st, 2012 08:35 pm |
Tan121
Posts: | 23 |
To ident: Last version did not work with 2.3
That version I have not tried.
Also still question about hiding unused zones. Would it be possible to hide unused zones, i see 64 (something like that) zones, but i am using only 7 zones.
Posted: Sunday Jul 22nd, 2012 02:56 am |
The unused zones should not be shown
That is a bug which is now listed in the "Known Issues" List and will be fixed in the next version
Posted: Sunday Jul 22nd, 2012 12:35 pm |
Posts: | 557 |
I finally installed 1.82 on Android 2.3.3 (HTC Desire) and I get a 'Force Close' message when I press the Key button. 1.80 worked fine.
Another issue is that I lost my file asociation to the config file. When I click on it it doesn't seem to be associated to the Comfort App. Reinstalling doesn't help.
Posted: Tuesday Jul 24th, 2012 07:36 am |
Posted: Tuesday Jul 24th, 2012 07:47 am |
Posts: | 557 |
Yes, 1.8 installs fine.
Just a note: When I login, and the system is already armed, I don't get an indication that it's armed. I use two UCM/Ethernet's, one for ComfortClient and the other for Remote access.
Ok, this is odd. I installed 1.8 again, then uploaded my modified cclx file and reinstalled 1.8.2 and it seems to work. The above issue seems to be resolved using 1.8.2. Perhaps something was left behind in the initial 'Uninstall' of 1.8 that 1.8.2 didn't like.
Posted: Tuesday Jul 24th, 2012 02:07 pm |
Posts: | 557 |
Before I forget... The application sounds, like Countdown and Arming, on my HTC Desire seems to be extremely loud. Can it be made to follow Media or Ringer volume?
Posted: Wednesday Jul 25th, 2012 04:14 am |
Tan121 wrote: To ident: Last version did not work with 2.3
Also still question about hiding unused zones. Would it be possible to hide unused zones, i see 64 (something like that) zones, but i am using only 7 zones. We have checked that unused zones (Zone Type 0) are not shown in the app 1.82
If you use only 7 zones, and the other zones are Zone Type 0 (Null) then they should not be appearing in the zones list
Posted: Wednesday Jul 25th, 2012 05:00 am |
Posts: | 557 |
I also see zones even though they are Null. That said, I don't see zones 65-96. Here are the difference between Zone 64 and Zone 65. Perhaps ZoneTypeName is not as 'Null' as it should be.
<Zone Number="64" Name="Zone64" ZoneTypeName=" " ZoneWord1="Bypass" EntryPath="false" Restore="false" Partition="0" VirtualInput="false" Announce="false" />
<Zone Number="65" Name="Zone65" ZoneTypeName="" EntryPath="false" Restore="false" Partition="0" VirtualInput="false" Announce="false" />
Posted: Wednesday Jul 25th, 2012 06:10 am |
What zones can you see which are Nulll Zone Types?
The zone type name for Null is ""
Posted: Wednesday Jul 25th, 2012 06:34 am |
17th Post |
Posts: | 557 |
I can see all 64 zones, even the ones setup as 'Null'. Zone 65-96 has not been modified since they were added by Comfigurator, I suspect Comfigurator has an issue where it inserts a :SPACE: instead of a :NULL:
Posted: Wednesday Jul 25th, 2012 06:52 am |
18th Post |
Posts: | 557 |
I just confirmed, as soon as I edit Zone Type to something else and set it back to 'Null' then it inserts a :SPACE: character.
Posted: Wednesday Jul 25th, 2012 06:56 am |
19th Post |
Can you send your cclx file to support@cytech.biz so that we can check the problem
as e do not see this with our own testiing
Posted: Wednesday Jul 25th, 2012 06:58 am |
20th Post |
OK let us test this. Dont need to sendyur cclx file for now
Current time is 08:30 am | Page: 1 2 |
