Problems in knx2
 Posted: Tuesday Nov 7th, 2017 06:37 am
marcobeleza
Every time i start the configurator with last default file the program reports the following mistake and the software don´t start.
System.NullReferenceException: A referência de objecto não foi definida como uma instância de um objecto.   em Comfort.UcmKnx2ToComfort.get_RegisterName()   em Comfort.UcmKnx2ToComfort.AddReferences(Dictionary`2 references, UcmKnx2 ucmKnx2)   em Comfort.UcmKnx2.AddReferences(Dictionary`2 references)   em Comfort.Configuration.BuildReferences()   em Comfort.Configuration.GetReferences(ConfigListItem configListItem)   em Comfort.Response.FlagOmittedResponses(Configuration configuration)   em Comfort.Response.EncodeResponses(Configuration configuration, Boolean flagRequireWriteToEeprom)   em Comfort.Form1.SetNewConfiguration(Configuration newConfiguration, Boolean keepPanel)   em Comfort.Form1.NewConfiguration(String filename)   em Comfort.Form1..ctor(String filename)   em Comfort.Program.Main(String[] arguments)
My configurator ver is 3.12.1 but i think the problem is with the latest update to knx2 of my knx ucm.
Can someone help me ?
Kind Regards,
 Posted: Tuesday Nov 7th, 2017 06:52 am
Please send your cclx file to support@cytech.biz so we can check
Please make sure that you ave done a scan for modules and have saved the file
 Posted: Saturday Nov 11th, 2017 04:38 pm
marcobeleza
Ok,
I will send the file through email
Thanks,
Marco
 Posted: Sunday Nov 12th, 2017 06:24 am
I opened the file Alarme 1_11_2017 but did not get any exception, even if set to Open Last File
Does the problem still happen for you?
 Posted: Sunday Nov 12th, 2017 11:33 am
marcobeleza
Thanks for the reply. The problem was with the installation of Configurator, and not on the cclx file. I´ve done a fresh install and everything works well now. I clean all files on the installation directory before installing the new configurator.
Thanks,
 Current time is 11:01 am
