KNX Test Buttons
 Posted: Saturday Jun 20th, 2015 12:37 pm
In the KNX configurator screen, after adding or learning KNX addresses, select the KNX group address in the centre pane, and press the Switch Device ON or Switch Device Off buttons (on the right pane) to test the KNX address.
This should switch on or off the  KNX device. It is not necessary to WRITE to EEPROM for the UCM/KNX to use the test buttons. See the screenshot below
However, there is a BUG in Comfigurator up to 3.10.4 - The Test buttons do not work for KNX group addresses 1/7/X (where X is the subgroup). This is a problem for the test buttons only, but the actions to send a command to control 1/7/X will work
 Current time is 07:30 am
